Oo.
I have received our first PacBrake Exhaust brake for the 03's with a stick shift..... The PacBrake Part number is C14030..... with this first unit which is sold, we have set our selling price at $ 895. 00 which I assume from watching this board is lower than the other competive exhaust brakes... ... This price includes a 10% discout to TDR members.....
I can only assume that my stock order is just around the corner after the first of the year... ... .
The housing is much larger than I expected which accounts for the increased flow required for the higher HP of this new engine design... . It is a direct mount design for mounting direct to the Turbo like the previous models... ...
The exhaust brake is powered by an air compressor which supplies air to an 1 1/2" air cylinder... . this system is the same air compressor and related parts that is used on some of the Cat and IH engines that have exhaust brakes available for them... . Because of the larger cylinder and valve the compressor is larger as well... ... The compressor is designed to mount to the firewall in holes that are pre-existing... .
It wires into the ECM and will be contolled by the ECM..... It also uses a clutch interlock switch so that the exhaust brake turns off during clutch operation... .....
An optional gear shift lever switch is available which carries a part number of C18042 for the 16. 5MM diameter gear shift lever.....
In addition to the new exhaust brake, PacBrake has introduced a new Lube for all exhaust brakes... ... Its a Synthetic Lube for maintenance of the valve and moving parts where the exhaust brake is left off part of the season or for RV or Motorhome use where the vehicle sits for extended periods of time..... It carries a part number of C18037 and is suggested for any exhaust brake... .
If you have any questions please let me know... .
Have a great day... .
