New projector headlights and LED taillights
Front U Joints Are Bad
Wanted-2008 Ram Tail Gate
Well as you might have seen in another post, I got new headlights. I am now posting pics and giving my impressions
here is my right headlight, note the gap at the fender. . apparantly this is what alot of them have...
/webdata/photopost/data/573/medium/IMG_1529.JPG#ad
Pic of the left headlight with park lights on. . note the 3 LED spots and the Halo Ring around the projector
/webdata/photopost/data/573/medium/IMG_1530.JPG#ad
Here is the main headlight on. . you can see the LED's better. . this part of the lights are plug and play for the connector
/webdata/photopost/data/573/medium/IMG_1531.JPG#ad
This was the hard part to get both lights working... I just wires up the inside lights like a fog light with a separate switch through a relay.
/webdata/photopost/data/573/medium/IMG_1532.JPG#ad
Just got these today and they work perfect. . They are 18 LED Lights for running and signal. . there is a resistor built in and is all plug and play with this. . . you can clearly see the LED running lights during the day and the signal light is very bright like a Cadillac has. the bottom pic is when the bright signal is on... see the difference between the running and the signal
/webdata/photopost/data/573/medium/IMG_1533.JPG#ad
/webdata/photopost/data/573/medium/IMG_1534.JPG#ad
/webdata/photopost/data/573/medium/IMG_1535.JPG#ad
You bet let us
know where you got them and if they are worth a crap????? I mean are they bright - the POS we have now is almost worthless... ...
This is where i got the lights
The taillights are blindingly bright at night. . very good. . You can see the running lights during the day so they are good.
eBay Motors: 94-01 DODGE RAM LED TAIL LIGHTS 95 96 97 98 99 00 2500 (item 400010924304 end time Mar-20-09 14:55:09 PDT)
here is a search of other kinds where there is black and smoke and others
94-01 dodge ram LED Taillights, eBay Motors items on eBay.com
The headlights are pretty good, long light on the high beam, the low beam is a nice wide projector pattern. . light has adjusters and is pretty easy to aim
This headlight is close to what I have. .
eBay Motors: 94-01 DODGE RAM HALO LED 1500/2500 PROJECTOR HEADLIGHTS (item 200311948143 end time Feb-23-09 22:18:05 PST)
Here are some to choose from
94-01 dodge ram projector headlights, eBay Motors, wii items on eBay.com
so your projector style lights are adjustable. I was told that they were not adjustable and a pain in the butt. since I have a 6" I need adjustability.
The projector uses a H1 , These lights are Tiawan imports not a lot better that what we have. The projector acts as the low beam and the reflected bulb acts as the high beam. This is to satisfy DOT
I really like the tail lights - would probably get them, if I didn't already have these:
I'm curious as to how effectively the projector lights light up out to the sides of the roads - the Sport Light type I have, with conventional bulbs, do a fantastic job out to the sides as well as forward - effectively 180 degrees of very usable lighting. That can be critical out in this country, where a dashing deer or lumbering Elk is very possibly approaching the road from off to the sides... :confused:
Always interesting to see new options - thanks Eric... :)
The light gets bent in the projector and It reaches to the sides just fine... The projector has a 180 deg lense that does this
That kind of thing bugs me a lot, proper fitment. . . I had a similar issue with my Depo Sport headlights. I was thinking about getting the Anzo units from Geno's, the few reviews I've read were pretty good.
It looks good Eric, other than the gap on the front ones. Really like the LED's in the rear. Can you replace the lights individually on the LED's or do you have to replace it as an assembly? I got LED's on my cap and there are some that have gone out but i have to replace the whole thing. :{
I purchased a set of projector headlamps for my 03 and installed one, then compared the light output, my stock put out more light (hard to believe), so I packaged them up and sent them back. I am still waiting for a quality retro for my truck. <O:p</O:p
<O:p></O:p>
I purchased the IPCW Taillights that only lasted 2 months, half of the LEDs were flickering on and off or just stopped working. I called the company to see if I could get a replacement or refund, they told me to take them to someone certified to fix them. (The LEDs and electronics are sealed into the lighting unit, they would have to break the housing to fix). I purchased a pair of Euro L. E. D. Tail Lights which are much brighter and they have lasted 2 years so far and going strong plus they are 100. 00 cheaper than IPCW. <O:p></O:p>
<O:p></O:p>
I purchased a pair of Euro L. E. D. Tail Lights which are much brighter and they have lasted 2 years so far and going strong plus they are 100. 00 cheaper than IPCW. >>
Is EURO a brand name of Taillight... ... ... ... ... guess I could GOOGLE, but asking for clarification.
Did I read where HELLA made LED tailights for 3rd gen DODGES ????
Anymore prices and suggestions
