new pusher pump
Injectors - Jammers or Machs
Cam plate position for winter
i bought a holly blue pusher pump and i'm wanting to know a good place to mount it , also i would like to wire it in so thst it would run with the stock lp. my pu is a 99ram 3500 long box thanks forany help . jim
I'd look for a spot on the frame back near the tank. You can splice into the wiring harness for the stock pump and use it to activate a relay. Power supply for the relay can come from a fused line connected directly to the battery.
Ideally you'd put in an auxillary fuseblock for it, but you can do it the "quick and dirty" way if you want to be done faster.
-Ryan
