New Ram Hemi at work
Bought a new 2105 TDI Passat
D
2015 Durango VS Tahoe
AMink
I just got a 2015 Ram 2500 4x4 5.7 Hemi regular cab at work. I am surprised what a rough ride it has. Seems like an otherwise nice truck. My '06 3500 Mega has a better ride. Is this common with the coil rear end? I do like the 10 cupholders though!
AMink, it's likely got 80 psi in all tires. If you're only using it for transportation...no hauling, you can take the fronts down to 50psi, the rears to 45 or so and it'll ride much better. If a low tire symbol comes on, a piece of black tape makes it go away. Now it you're towing or hauling more than a few hundred pounds my suggestion may not be the way to go.
I'll give that a try. The tire pressure monitor (how cool is that?) did show high pressure. Thanks!
