NEW Ring and Pinion for 2003-2006 Ram 2500 Front w/3.73 ratio?
transmission probe
Does anyone know where I can buy a new front axle (AAM 9.25) ring and pinion with 3.73 ratio for my 2004 ram 2500? AAM discontinued the gears and no longer sells them, it also appears that Yukon does not sell them either. Does anyone know why?
AAM sells a 2007+ front ring and pinion (3.73 ratio) AND you have to buy a new "loaded carrier" which is an open design. This combination of parts can be used in '03-'06 ram 2500/3500 with AAM 9.25 front axles.
I'd like to buy an Detriot truetrac with my new gears; however, Detriot only sell a truetrac for '03-'06 AAM 9.25 axles, apparently it won't work with the 07+ gear set.
SO,... if you want and Detroit truetrac one that fits your 2003 - 2006 ram you have to use your old gearset...
Anyone have any luck with other options?
I don't have any answers for you but I'd love to hear how you like your Truetrac in the front diff if you get it figured out.
I love mine. You don't even know it is there other than you just have more traction. Every time I thought they might not be working it was because all four wheels were spinning. ;)
