New SMARTY files...
Transmission Adjustment Issue
5.9 pre lube kit
Are the new SMARTY files dated 16 May designed for the new UDC coming soon? I loaded it on to my S06 POD and the option is no longer there to adjust timing/RP/TM; upload a CaTcher and thats it... .
I wonder because the file name has a "U" in it where in the past it was usully an "A"
Yes it is for UDC, and the Adjust Options is there but has been moved. When you go to tune the truck it will ask you for them.
I have already tuned the truck but the options werent available when I did it... I am in default SW3 because the adjust options werent available.
Interesting, that is where they were on my SJR.
The menu's are a little different on the two, but on mine.
Main Menu
ECM/ABS Update
ECM Update
Present
Select SW1, 2 or 3
Adjust Options or Program SW then appears.
I hate to say this but after Mads 513B S/W update a couple of weeks ago, I ended up with the "RivalGaming" malware. Of course I can't say for sure they were the source but that is when it started and it's damned hard if not impossible to get rid of.
Proceeded with caution.
