This is FYI to those who have had lift pump problems. I was in at Schied Diesel today and was told of a new product that may well help if not cure failed lift pumps on Dodge 24V specifically.
Now, before you go calling them, there will be an article addressing it in the upcoming issue of TDR. Plus it is not available now, but should be in a couple of weeks. It goes something like this... .
They, in a joint venture with a reputable company that makes fuel pumps and such, have spent the last couple of years understanding why Dodge Cummins 24V LP's fail. In conlcusion, this new device consists of an additional lift type pump along with a filter system, all of which attaches to the engine near the air horn area... easy access. The way I understood it, it draws fuel from the tank much in the same way as the OEM lift pump and filters it, in turn supplying clean slightly pressurized fuel to the OEM lift pump. Fuel debris has been found to be a leading killer of OEM pumps among other things. After it is all said and done, the injector pump will see around 5 psi or so higher than any stock lift pump has ever produced, resulting in increased life spans for the VP44's. All this stuff mounts underhood for protection. And its powder coated for good looks.
I also understood that this was going to be different than just a pusher pump and the 24V engine was in mind during design so reliability and performance should be on que. They have used their own trucks for research with great results.
Now, I in no way am associated with Schied. I just wanted to pass this along since I know it is a problem many have faced. This looks like a great solution and I sure hope it works for them and everyone. Just keep your eyes peeled in the next TDR for their official description of the system. Like I said too, its not available yet, but should be in a couple of weeks. I'll keep checking and let the forum know if I can get my hands on one for my truck. Hats off to Schied for even addressing this issue for the masses.
