2nd Gen Non-Engine/Transmission New Tires Coming Tomorrow!!!!!!!!!!!
Engine/Transmission (1994 - 1998) who knows
Engine/Transmission (1998.5 - 2002) hard start
after 2 weeks i am getting my swamper trxus mud terrians delivered tomorrow. im adding to my skyjacker 4,5" kit. i went w/ hell bent steel 2" coil spring spacers an t. country 2" lift blocks. the new rubber are 37 x12. 5 x16. 5. i cant wait to get this on! it should look bad *** when im done. truck should sit about 3,5" higher when all said an done! Oo.
Hey- How did you get through inspection with your exhaust setup? I have to go through this month and they're supposed to be doing visual inspection for the cat and onboard emmisions diagnostics. I'm straight piped and want to go to a dual stack setup or 5" straight system, but right now I'm thinking I'm going to have to clamp the cat back on for inspection. Also, did you do the stack setup yourself? Thanks!
97 2500 4x4 SLT extended cab / 35'' MT Baja Claws / #8 plate / straight piped / all Amsoil / 246,000 mi
