Tuesdak
Just picked up a near stock 2003 3500 SRW quad cab 6 speed handshaker. Has a Pacbrake currently switch/compressor turned off. 1 owner with 100K on it. It will be the usual short trip daily driver and usually find a need for a truck to haul something now and then. Blow the carbon out at least 2-3 times a week. Clutch and water pump were changed in the past.
It needs some TSB's done like the ghost chime and slow fuel gauge. The PO noted the AC had to run in rec to keep it from freezing up. The temp sensor fix appears to be in my future...
Anyway some things I have noticed:
In gear the throttle likes to take the engine to 2100 RPM and then has a flat spot requiring a lot of pedal movement to continue to bring engine RPM up. It gets with it if you floor it. Normal?
Turning the key on I get a relay buzz noise under the hood for 30 seconds or so. It doesn't sound right. What should I be looking at or is this normal?
Has the original lift pump location in use. Any way to tell if this is the original lift pump or a updated replacement? Any pointers on where to test PSI for the lift pump? What PSI do I need? Is this pump flow on fail? What kind of pump is is? Would a Walbro FRB-5 plunger pump work or does it need a constant pressure rotary vane type pump?
I get a ticking noise in the cab on accelerating or higher RPM. Injection lines tightened and did not help. Sounds like an exhaust leak if I was to guess. Ideas?
Any fuel components not compatible with biodiesel? We are past the 'recommendations for warranty'. Lines, hoses, lift pumps, etc? Here in AZ they will give you up to 5% without a label on the pump. I have run B99 on other diesels (2500+ gal one year alone from a local commercial refiner) and had hose and lift pump compatibility problems mainly from the trace alcohol content. The diesel bug also bit me badly in the past so I keep everything dosed with a biocide. Likely won't run biodiesel, but as noted will run into low amounts on unlabeled pumps. Doesn't hurt to have upgraded components if needed.
