Engine/Transmission (1994 - 1998) new truck hp
2nd Gen Non-Engine/Transmission Dually Tires
2nd Gen Non-Engine/Transmission a/c problems
i know this has been asked a million times but i need some tdr wisdom. i just bought a 1997 3500 ext cab 4x4 5sp. it has 150000mi. with 16* timing, 370's l/c dv's, a zero plate and a dodgezilla how much power will this truck make. i know i need a bigger turbo but the wife said wait till christmas. thanks richard
I assume the dodgezilla is a modified HX-35... .
Where is you plate at? How big are the DV's?
If you plate is forward I would say 450+ and over 1000tq if everything is set up right.
my plate will be just a little back from full foward. i have laser cut dv's. also how can i tell if i have a 913 pump or a 887 pump? with the same things done to each pump will the horse power be about the same? the dodgezilla is a hx35/40.
i know sbc says the con-o is good for 400hp but what have some of you see it hold? the reason i ask is because thats what clutch i have and i want to know if i have to drive real nice or if i can use some of the loud peddle. thanks richard
