Originally posted by gbraden
I believe you are talking about a sliding 5th wheel hitch used with shortbed trucks. Correct?
My questions:
1. Would another truck with a regular 5th wheel hitch be able to connect to and tow your trailer? Or would you have to do some bolting on or taking off something first? If so, would it be a big deal?
2. Would you be able to use your Pullright equipped truck to tow their 5th wheel if their trailer had a regular 5th wheel hitch?
3. Do you know if the shortbed 2003 Dodge Quad Cab with the PullRight hitch can do a 90 deg?
I just had the SuperGlide 16K installed last week--Yes, it's an automatic sliding hitch, as noted above.
1. I haven't installed the adapter plate on my trailer yet. It is necessary to make the hitch slide, and it renders your 5th-wheel un-towable by standard hitches. It mounts with (about a gazillion) 1/4" countersunk bolts. On my pin box, the nuts would go down inside beyond arm's reach, so I bought nylock nuts. I'm still not sure how I'll install them (I'm thinking air ratchet), but removing them to tow the trailer with a standard 5th-wheel hitch would be a royal PITA. OTOH, the installer recommended *welding* :--) the adapter plate on.
EDIT: Hmmm, now that I think about it a little more, I wonder if the bottom plate of my pinbox is thick enough to tap? That would be much easier (the bolts carry only shear loading, but a lot, transferring the twisting motion of the trailer around the kingpin to the hitch to twist and slide the hitch).
2. Stepping into an area of less certainty, now, as I haven't tried it, but the installer said you can tow a standard 5th-wheel trailer with the hitch--just watch those tight turns. But when I think about it, I wonder what would keep the hitch from turning and sliding on its own.
3. I haven't taken measurements to calculate this, and since I haven't installed the adapter plate to try it yet, I can't say for sure if a full 90* turn is possible.
