New truck question
Got new trailer
No Drill Mount For 5th Wheel Hitch - 2500HD
ACoyle
Super Moderator
Is there a way to use my Reese 15K fifth wheel hitch on my new 04? I know the frame is funny.
Thank You
AC
I've used mine from the previous trucks an '01 and '03. New brackets required for the '03 but they work on the '04. The brackets need to clear the overload springs.
Check with Valley Industries which I belive makes the Reese hitch. They have a bracket system which I had installed on my 04. You have get another set of rails as I did. It works great. Also check with RV dealers. They should be aware of these brackets.
I re-used my 16k, like the previous post, had to buy a special kit (two rear brackets) because of the overloads... . also bought a new rail kit because I wanted to leave the old rails in my other truck. (But I think you might have to get a rail kit or an update kit anyway, because of the boxed bed rails... )
About $70 and $100 respectively. I guess there is a no-drill (frame) kit from Reese... but for the 2500's only.
Went pretty smoothly... I'm just slow. The special size carbide drill bit for the frame was a bit of a pain to find... I still had mine from the last install, but don't expect to find it at HomeDepot or the such, just go straight to a professional tool store.
This time I had to buy a 1" hole saw because of the "boxed rails" under one part of the bed. (You use a tubing spacer to prevent crushing)
(That went pretty smooth, but next time I would use the tip I read here about using a piece of wood to prevent walking!)
Also I ended up making the bolt snake a little longer so I could use different holes in the frame... make sure you secure the extension so you don't lose it and the bolt inside the frame!
DanDee
