Sway control (wind) and tongue weight are your biggest concerns. Towing a TT is easy once you've got these handled. I assume that the dealer sold you a weight distrbution hitch, which is a must. Dealers sometimes set up buyers with the wrong bars (usually too stiff). You will also need to install sway control, but the add-on friction type are not the ideal solution. There is a lot of info at woodalls.com on towing. Very good tow vehicle and towing forums. You will need to navigate the site a bit to find the forums, but it is worth the effort. I can personally recommend the Equalizer hitch, and many others do as well. It combines WD with sway control. The hitch bars should fit your 29 but you will need to check. Equalizer web site has good info on the product, but unit is pricey (about $650) from them. Even if you already have a hitch and sway control from the dealer it's worth a visit to rvwholesalers. com. They sell the original Equalizer for $399.
