Hmm guessing an Hx40 or such? If so hand bolt her up first without oil lines and such and clock the housing to match your old turbo outlet (Sometimes they are not clocked right and you can even get to the last bolt then realize it)
I SLOWLY spin the blades while putting oil in it (VERY LITTLE as it does not hold much when not under oil pressure) as that will coat the shaft quite well.
