BigPapa
Today I replaced my VP seals. I separated the VP and PS pump before removing the VP using these instructions that someone else posted on another website:
I had read all the threads I could find on the TDR and the general consensus was to remove both pumps as a unit and put them back in as a unit. This method involved removing or cutting the PS hoses which sounded awfully messy and alot of trouble. I removed the driver side battery and the turbo pipe between the intercooler and the intake horn and the bracket for the spring that is mentioned above. The biggest problem I had was getting to the upper bolt closest to the engine that holds the PS pump to the VP. Both the bolts on the engine side were easiest to get to from below. If you had a stubby 15mm box end wrench you might could get it loose from above. I had read that the oil line for the VP had caused some people some major problems so I had a new line and fitting on hand just in case but mine came loose very easily. I used a standard open end wrench on it from below. I don't see how you could get a line wrench on it. I put the two pumps back together before bolting the VP back on so that I could turn the gear on the front of the VP in order to line up the drive dogs on the PS pump. Never spilled a drop of PS fluid. All in all it was a pretty straight forward job. It took me a little over 3 hours but I feel I could probably cut that in half if I had to do it again.
Don't be scared!
Scott
1. Remove four nuts securing Power Steering Pump (PSP) to Vacuum Pump (VP). Studs may back out of PSP. Just thread back in. Leave all PSP hoses connected. There is a spring aft of PSP on the injection pump that can get in the way. Disconnect and let hang. Do not separate PSP from VP yet.
2. Remove VP supply line and oil line at the bottom of VP. You may need to back up the fitting (7/16) at the bottom of the VP and then remove the oil line (9/16). You will get some oil drainage so be ready with a small pan.
3. Remove lower bolt attaching VP to gear case. Loosen but do not remove upper bolt completely as this will allow the whole assembly to hang down at an angle providing more room to separate the assy.
4. Gently separate PSP from VP taking care not to scar the sealing surface becoming visible attached to the PSP. Rest PSP on engine mount.
5. Remove upper bolt on VP and remove from vehicle.
6. Keep things clean. Remove two bolts and separate VP halves.
7. Set the PSP side (four legs) of VP face down on bench. Fit a deep socket (large as possible) through the hole in the center and drive the center section holding the seal from the outer housing.
8. Remove old seal and press in new. Clean all o-rings and lightly lube with grease including inside diameter of new seal and sealing surface on PSP.
9. Install center drive star and seal center section into housing. Assemble both halves of VP making sure there is no dirt inside the VP.
10. Install components in opposite order of removal. Clock drive fingers on PSP to VP to help in mating PSP to VP.
11. You just saved yourself $1000!!!!!
Don't be scared!
Scott
