Well I just installed a reman VP and lift pump in a customer's truck, fired it and it's only idling on 3 cylinders. It ran long enough for me to assume all the air is bled out of the pump and lines. Cleared the origional Inj. pump timing failure code and no codes returned. I had no snags installing this VP... it was the easiest install I have had yet. I checked the keyway 3 times during install to make sure I had it right. Think there is any possibility of the gear turning on me? Maybe a bad reman pump? Any ideas would be helpful... I will double check the keyway first thing in the morning.
