My head gasket was starting to slowly leak out of a water jacket and I was already on borrowed time with my vp-44 and signs that it was giving me. I go to Source Automotive -- Main I had my head O-ringed and studs put in. went from 100hp jammers to EDM Mach 4's. the shop put on a donaldson fuel/water seperator filter between the tank and my fass pump. I still use the factory filter as well. (this done due to crap always in my stock filter housing) better cheaper filtering done. same time drop tank check it and install vulcan big draw-straw. ( now my fass is quieter). valve-train was kept the same except Top hat valve seals were used (later for twins). the truck is great now I have 500 miles on the truck and I'm getting better MPG and less smoke the Mach 4's are pullers the pull through I feel my throttle all the way.
my truck would smoke crazy on any setting on the smarty. now only if its sw7 or sw9 and I hammer it. my truck isnt as loud and knocky. it idles smooth. So I hope this helps others out there on decisions. I have always went to Rip at sourceautomotive they have always been great to me and quick and very knowledgeable. (next is 3600 DDsbc my FE is slipping)
2002 HO 6-SPD LB 4X4 QC HTT 62/14 SB-FE TST PM3+EDM MACH 4'S RINGED AND STUDS AFE/2 4"SILVERLINE ISPRO PYRO,BOOST,FUEL GAUGES,
TURN-OVER BALL, RIDE RITE AIR BAGS. FASS 95 W/DONALDSON FUEL FILTER, VULCAN DRAW-STRAW, VULCAN 3/8 FUEL LINE AND FITTINGS, FUEL PRESSURE GAUGE, DSS 03 TRAC-BAR DSS BOX SUPPORT 17'' KMC BLACK HOSS, 305/70/17 PRO-COMP X-AT'S COUPLE OF STUPID STICKERS AND DE-BADGED FOR FUEL MILEAGE. :-laf
