The overflow valve on the VP44 is designed to open at 14psi, thus dumping fuel back to the tank. If the valve is stuck in the closed position, you can receive a DTC indicating a "High Injection Pump Fuel Temp". This is due to no "circulation" of fresh fuel. We all know the fuel is the lubricant and the coolant for the pump. The acceptable minimum pressure (per the manual) of the lift pump is 10 psi (pre-filter) this is not enought to trip the overflow valve so circulation is achieved through a constant flow of fuel to the injectors. At idle you do not have a constant flow, the ECM provides just enough to prevent shutdown. Thus explains why it is not good to idle the 24v for extended periods.
Those of you that have added a pusher pump and are getting pressures over 14psi have a constant lubricating and cooling system for the VP44 as well as helping the lift pump.
It would then seem to me that the ideal solution is a single pump back by the tank, that give you a minimum 15psi at the VP44 (post filter or filters) but provides a flow rate high enough to prevent low power due to bypass of too much fuel.
So my questions is, does anyone know what the required flow rate (gph) of the VP44 is at WOT. If we can find a single pump that slightly exceeds the require flow rate and exceeds 14psi at WOT all our problems would be solved. (I'm knocking hard on wood here)
-Matt
-Matt
