Hello TDR members and moderators,
I'm kind of a newbie to this site and Cummins diesel. In my research I've come across a few things that I'd like to pass by the TDR members in hopes of getting a bit of advice and answers to a few questions. Keep in mind that I'm willing to be wrong on what to do and not do when it comes to my 1999 Dodge Cummins 4X2 automatic Quad cab.
It's a daily driver / work truck that pulls an equipment trailer that is under 1000 lbs. I'm not going to race it but wouldn't mind the additional power to blow past grandma doin 50 in the fast lane with my trailer and all.
Here's a list of the modifications that I plan on doing;
= need advice and or have questions about
1. Fass DDRP fuel pump
2. LED low fuel pressure indicator
3. K&N or AFE cold air intake box and filter
4. Fuel injector upgrade to medium - medium high out put
5. Mag-Hytec double deep transmission pan
6. Reroute the transmission fluid cooler to the front of the radiator not inside it
While doing my research on the fuel pumps I have decided on the brand Fass. I don't know if the DDRP is going to be good for my application or if I should go to the HPFP 95. In addition to that it made me curious that 1/2" lines are recommended with no mention of 1/2" valves, banjos or fittings from the tank to the fuel filter and the VP44. Am I missing something here? Are there fittings that are 1/2" that I haven't found that will get past these choke points? If so where? I'll use them and step up to the HPFP 95 with 1/2" fuel lines. I don't want to increase my fuel pressure to the point of it finding the path of least resistance and creating an unnecessary leak.
The other thing that I'm wondering is why put the pump in a location that is so hard to get to. Can it be mounted to the rail where the vibration is far less without suffering any GPH or fuel pressure loss? If I'm not mistaken these pumps pull and don't push.
Now I'd like to get schooled on K&N vs AFE and what the difference is between stage 1 and stage 2 filtering.
I'd like some advice on injectors that aren't going to blow up my engine. I'm not too worried about economy as my fuel will only cost about $1 per gallon. (keep reading, I explain my fuel cost at the end) I'm more into the additional HP without breaking my bank account.
I'm curious about getting another cooler for my automatic transmission fluid to put in front of my radiator. Is this an option?
Also if there's anything else that I'm missing in modifying my truck I'd really like to hear about it. As I said in the beginning of this note I'm very new and am open to advice.
I plan on making my own fuel by Diesel Secret Energy. (DSE) If you want to know more about DSE go to Diesel Secret Energy - Alternative Biofuel Biodiesel which is why I'm wanting to make the modifications before I run this new better fuel.
I'm thankful that I bought my first Cummins because after a few tweaks it's going to be a bullet proof truck. Oo.
Eric
Eric
