Newbie could use some knowledge
Low boost
New rig gauge questions
I am a new owner of a Dodge Ram 2003. I am not a mechanic but would like to learn as much as I can about my truck.
I have some dumb questions, but here goes. Also this is my first post on TDR.
I know there is a 12 and a 24 valve engine also a common rail engine. How do I know which one I have?
What my engine displacement?
How many cylinders?
System Voltage?
Horsepower?
Injection Pump Type?
I have a manual 5 speed Trans. I read a thread full of arguments for each so no need to add yours here.
Thanks for your knowledge and i'll have many more stupid Questions to come.
-SG
welcome to the TDR, the toughest place on your wallet :D Lots of good info here but don't believe everything you hear
1. 24 valve HPCR High pressure Common Rail
2. 5. 9L of diesel enjoyment :D
3. I-6
4. 12vdc
5. Anyone? 2003 have an HO or was that just 2004/2004. 5?
6. CP3? Don't know for sure
The only stupid question is the one that gets you stranded because you didn't ask
First, welcome.
JApol did a pretty good job of answering your questions.
HP-Look on the right side of your engine, there is a sticker with all of the pertinent info there... with the 5-speed, I beleive it to be a Standard output engine, not the High Output Version.
Injection pump is definately a CP3.
BTW, there are no stupid questions if you do not know the answer.
Mike
3. I-6
4. 12vdc
5. Anyone? 2003 have an HO or was that just 2004/2004. 5? There were HO's only with the 6spd until 1 jan 2003 and then they were '03. 5 and they were available with the auto and 6spd.
if you have the 5spd, you have 250hp/460tq.
6. CP3 it isn't exactly an injection pump like the older trucks, it doesn't control anything other than pressure
JApol is right, I just added a little.
