Guys,
I'm finally getting around to my gauge installs. Westach EGT/Boost combo, 30 PSI fuel pressure and Dual temps (one to transmission).
The fuel pressure works great hung via the extension hose off the schraeder valve. woo hoo. I started getting 216 codes last week (reason I finally got off my behind and did my installs. ) At ide I'm at 12 PSI, so I'll be watching this closely.
For Boost, I am using the bolt provided by Geno's in the 3rd from firewall closest to valve cover position.
For Pyro, I tapped my Ex Manifold.
The BOOST and EGT at idle are very low. Boost doesn't register on 30 PSI on Pyro is only 300 deg F at idle. I expected both of these to register higher at idle.
My question: At idle, what should my boost register? what should pyro register?
For clarity, I'm stock today.
130,000 on original lift pump fixing to buy the Vulcan relocate kit...
