The high end travel trailers had shock absorbers from the 1960's onward, upmarket from Airstream:
Silver Streak and
Streamline. Optional on the "bargain" models and standard otherwise. These two manufacturers stayed with leaf spring through the end of production, 1995 (one or two years of torsion at very end) and 1974, respectively.
AVION went through several suspension designs over the years and had a Henderson walking beam design (MOR-ryde) in the '60s/70s, then a stub axle leaf sprung set up that separated the opposing sides from one another. (Some one ask ol' Uncle Harv, he had a couple of these).
Cost, here, was not an object as these trailers easily cost as much as the average American house back in the 1950s-1970s. The market, and society changed, and Airstream survived only because one deep pocket manufacturer wanted it for a prestige brand. Gotten mighty heavy the past generation for a given length, but no comparison to other TT designs now available. Airstream still uses shocks on their torsion axles . . and has no plans to change this after more than fifty years. They work here as well.
Shock absorbers are more than worthwhile as they dampen the action of the springs . . otherwise the tires have to take the load "peaks" and that adds to tire heat. Slowing the rate of movement means most on the worst roads, and in situations where the opposing side tires are meeting different obstacles.
Spring mount cross-members were also stock on
SS trailers (too many years -- decades -- since I looked under my grandparents
Streamline). I think we all know to keep travel trailer tires to full sidewall air pressure as the forces acting on the tires in turns wants to tear the tires from the wheel. The leaf spring is also acted upon. Cross-member and triangular gusset to the spring mount are both good ideas. Not the same as a Panhard rod, but keeping forces in place is part and parcel.
Fancier equalizers tend to increase wheel travel. The main advantage of torsion axles is that one has now a truly independent suspension due to both wheel travel increase and being uncoupled from the other axle AND that the roll center is considerably widened as a result. On a leaf sprung trailer the "outer edge" is at the spring clamp, with the torsion axle it is move to the face of the wheel. Note how much trailer is "outside" the spring clamp when viewed from rear.
A torsion axle trailer is much more stable as a result. Torsion axles are a true upgrade . . their downside is that they tend to "dry rot" or "lot rot" when not exercised. Service life is shortened from maybe 20 to 15 years (many conditions apply). They are also dirt simple with next to no parts as compared to L-S.
Low center of gravity is always good, but torsion axles are what make it work:
"Why Airstream?"
MOBILE OUTFITTERS (LIPPERT aftermarket catalog) has upgrade kits in re shocks, etc.
And a DEXTER dealer can help convert to torsion flex.
John Barca on TT shock absorbers
http://forums.woodalls.com/index.cfm/fuseaction/thread/tid/24776971/srt/pa/pging/1/page/1.cfm
John Barca on Spring Hanger Cross Members
http://forums.woodalls.com/Index.cfm/fuseaction/thread/tid/24796694.cfm
