Newby intro and the charm of the Ecodiesel
They are starting to show up
Who Will Be First?wWh
I ordered a Ram 1500 Ecodiesel a couple weeks ago. Truck is still in a "Production Scheduled" status. Being an American boy, the wait is hard.
A lot of 1/2ton pickup owners wonder what the charm is for a truck that gets a little better mileage, but wants more expensive fuel, not to mention the urea stuff. 3/4ton owners laugh at the cargo capacity. I think I'm in the sweetspot for the Ram Ecodiesel tho. It will be 50% daily driver and once/month it will tow a 7000lb enclosed trailer 7-16hrs round trip. Right now that role is filled by a 2000 F-250 7.3l diesel. I get 12.5mpg both towing and in daily driver mode. I've poured over the web reading every scrap of info I could find re. the Ecodiesel and I'm thinking I'm likely to get 15ish towing and >25mpg as a daily driver. That's such a huge difference in mpg that it will cover a nice chunk of the payments.
Sure, gasser trucks can get decent mileage, but gassers struggle towing. I could get something with a big V8, get decent daily driver mpg, but then get 7mpg towing and that would truly kick my ***. The gasser fans point to the high cost of diesel, but since this is primarily a diesel forum, you guys know that if you shop a little for diesel the price isn't that much more than mid-grade gas. Towing a heavy load with 87 would be just wrong.
Sure, the 1500 is a bit limited in cargo capacity and that's a bummer. The payload of my unseen Ram Big Horn is apparently 1400lbs, which ain't a helova lot. But I'm running 800lbs of tongue weight so as long as I don't have a bunch of crap in the bed I should have enough spare capacity to keep the lawyers at bay. I did figure on putting some airbags inside the rear coil springs tho. Otherwise folks might laugh at me as I cruise down the freeway pulling the trailer with the truck's rear end on the bumpstops.
I'm in Savannah, GA. a cute little tourist town on the coast. Former Marine and Army. Now a computer geek married to a lawyer-chick with 3 boys in grade school. Obsessed with racing an 80's BMW and triathlon. And beer. Am often a wise-***. I'm pretty handy around old BMWs, but I don't know a darn thing about Rams nor pretty much any other modern car/truck. I had a '99 Dodge Ram 5.7l once. It is not remembered fondly.
Ranger, you've come to the right place, and congratulations on your new purchase. Maybe you'll get it sooner rather than later. There are quite a large number of TDR members who are very knowledgeable on this website, but I would suspect that those who will receive their new 1500's will be learning right along with you. Of course, we all continue to learn don't we? Again, welcome aboard and have fun!
- Ed
Mine will be nothing but a highway driver with very little towing, the main reason I ordered was for the mileage. Hoping to get it sometime around the end of the month, it was six weeks from order to actual production which was Wednesday 3/19. If you ordered a two wheel drive you will see higher than 25, depending on how you drive it it may hit 30 or better. I put the air suspension on mine which meant I had to go with four wheel drive and I am very curious as to how it will ride.
I am waiting to see what the Nissan and Toyota with the 5.0 Cummins will get for mpg. Should be very good competition for Ram.
It sounds like this truck is going to be great for your use. Hopefully you will report back with your real world experience after daily driving and towing.
Before you go the airbag route I would put a good weight distribution hitch on the trailer and see if that will keep your headlights out of the trees. Properly dialed in hitch should give you a good driving experience.
I run a WD hitch. About 18 months ago I took the loaded trailer to the local truck stop and weighed it in every way I could think of. One thing I learned was just how much of a pitiful wretch my WD hitch was. It only moved 60lbs from rear to front. Since then I've figured out how to tighten the hitch one more chain link, but I've not weighed everything again since. If I had to guess I'd say that I'm now moving 90lbs front to rear.
I can certainly feel the difference in how the truck takes big bumps with and w/o the WD hitch, but I had naively thought that it was transferring more load.
Scott, welcome to the TDR. Lots of great folks are here to help you out as you become acclimated to the diesel world.
RP
