THANK YOU!!!!!Jengle and Tom,
These two guys helped me install my new Diprocol pyro, boost and trans temp gauges. The trans temp is not currently hooked up but the lights work, it is just waiting for me to install a new trans pan so the sensor can be installed and have that working.
OK, now its time to dust off some of those old brain cells as it has probably been a few years since you have seen numbers like this.
Max Boost: 33-34psi
Waste gate: 33-34psi
EGT(post turbo):
High:650
Low: 400
mostly 550-600
Boost during straight and level with cruise 0-~65: 5psi 65- up ~10psi
In the distant future I might put another pyro sensor pre-turbo. Is it possible to connect 2 pyro sensors together when same make/model sensor are used like in jet engines?
Oh man, I just thought of something, Now iahve to take pictures and put them in my gallery. OH WELL! Oo.
Max Boost: 33-34psi
EGT(post turbo):
High:650
Low: 400
mostly 550-600
