Next Bomb for Mileage?
Ordered a DTT street Race transmission
Turbo question
Hello,
Per my description you can see my mods. The box I use is the old Edge Fueling box, no timing.
I'd like to do a bomb that will give a slight fuel mileage increase. What would y'all recommend?
275 injectors? Or an EZ timing box to put on top of my Fueling box?
Thanks,
Chris
Hmmmm, didn't know the older Edge box was fueling only, since I started with an EZ and then upgraded to the Comp.
I'd suggest looking around for a used EZ or Comp to swap out for your older box. Injectors might help also. I went from 16. 0 MPG when bone stock to anywhere from 17. 5 - 19. 2 MPG when I added EZ & DD3s at the same time, so I can't tell you how much MPG was affected by either EZ or injectors alone.
Tom
