Engine/Transmission (1998.5 - 2002) Next level of BOMB
I have DD2's, DTT, gauges, and EZ box set on 2.
The next jump in power should require 4'' exhaust, EZ comp, HX35 hybrid (or HX40), and stronger intake hoses for the intercooler. If anybody is running this combo, I'd love to hear about it, or take suggestions to get into the 400+ HP class.
No need for stronger intercooler boots until the stock ones go bad.
Get a wire tap box, and a 40/35 hybrid and your probably there. Check out the Water Methanol setup, that will add the juice too and reduce your EGT's. Group buy going on right now for those systems.
Jeff
What Jeff says,
Except I wouldnt go to water unless you really needed it.
Like when your around 500hp or 600hp and want to cool down your EGT's.
You can do that now with just a modified, hybrid or larger turbo.
--Justin
