Engine/Transmission (1998.5 - 2002) Nice or not conversion
Engine/Transmission (1994 - 1998) D70 front?
Engine/Transmission (1994 - 1998) Transmission Codes
Ole man killed my 99 cummins with gas. So now I am trying to change my motor from the 99. Cummins to the 2001 cummins. I noticed that there is no crankshaft position sensor and it is blocked off where the 99 has it. How can I get the 2001 cummins to run. Do I need to use the engine computer from the 2001 with the harness where there is no connection. Do I need to use the anything else from the 2001 to make the engine run in my 99
I know the 98.5 and 99 are a strange animal, Some of the wiring is different soo i would use the pcm ecm and wire harness from the 2001. Some of the wires to the transmission use different colors on the 98-99 but they all have 8 wires. Good luck and welcome to the forums, I am sure some of the guys who have done this switch will chime in, if they see it seems most have bought newer trucks and the second gen's get forgot.
Use the search to find more posts like this one. https://www.turbodieselregister.com/threads/183941-2001-engine-in-a-99?highlight=99+2001+engine+swap
