Ok, now I've done it! Our 1992 Nissan 240sx has had a squeak coming from underneath the car when the clutch was pushed in. It was annoying me so I crawled underneath the car and pulled back the dust boot that covers the clutch 'withdrawal lever' (engages and disengages the clutch). I was going to spray some lube on the lever to try to eliminate the squeak, but before I even sprayed anything, I MANUALLY moved the lever and engaged and disengaged the clutch a few times from under the car to see if I could pinpoint the squeak. After I did this, I had my wife got in the car and pushed on the clutch pedal a few times. The first time she pushed it down, it took forever for the pedal to come back up.
To make a long story short..... Now the clutch has a huge amount of sloppy free play (that it never had before) and it catches right close to the floor. (before it caught about halfway up) I did NOTHING else to the clutch except move the lever manually from underneath the car.
What did I do???
I've got a wife that's ****** off at me because I couldn't leave well enough alone and I screwed up an otherwise normal (albeit squeaky)clutch on her ride! So much for my shadetree mechanic abilities...
Any help/solutions would be greatly appreciated.
Thanks,
Steve (in the doghouse)
What did I do???
Thanks,
