Nitrous and TST??
Which 6-speed transmission is this????
recall/no recall
Anyone run this. Right now I'm running the TST and TS Performance Ramifier stacked. Can I run drugs, especially nitrous with this set up? Also the way I understand it due to the common rail, max on straight #2 is a little over 500. Once I go to twins can I still run the nitrous for a little more kick above the limit of the common rail?
Yes, it will help burn the extra fuel from the TST. Also it will cool down the charge going into the cyl. Not like running it on a gas motor where if you run to much the motor is toast. All it will do is put the flame out till you turn it off.
Thanks I was mainly concerned if the nitrous would hurt the motor based on the way the TST changes timing and other stuff. Will also help temps till I can afford twins.
