Engine/Transmission (1994 - 1998) Nitrous???
Are any of you guys running a nitrous kit on your 12v? If you are what kit are you running? And do you like it, had any problems down falls? I am thinking of puting a kit on my truck but i want to get some advise before i do it. Thanks guys.
Have you exhausted all your available options as to making HP with fuel and air and feel the need for the additional HP gain of NX?
I like both and run both, water allot but not all the time. N2O on occation and I have my 2 stage setup so I can run the small solenoid or both with a simple 1/2 switch.
If you are going to run any large amount of N2O you are better off to rent a big 60 lb bottle and build a fill line to top the little bottle off. I usually get around 5 top offs per big bottle and it costs $125 exchange.
Just like last night I had so stuff to do so I popped the bottle in the freezer for a while getting it cold for the transfer that topped the 15 lb bottle off with 10lbs
Jim
