I have a 2002 2500 ext cab with the factory trailer harness. There is no power coming out of the 12v+ tab. I can not find a fuse or relay to control this. The trailer fuse and relay are fine. My 2004. 5 3500 has a fuse in the junction box. The trailer wiring and brakes all work fine except for this. I need it to keep the break-a-way battery charged.
I didn't buy the truck new so I am not sure if this was ever operational. I know on Chebbies and Ferds the fuse needs to be added to the junction box. Maybe the same case here or a wire tied in that is taped up some where waiting to be hooked up?
I know isolators should be used and all that, I am just looking for low amp source as it should work and be.
Thanks
Thanks
