The axle is actuated by the CAD. If you look on the passenger side of your front axle, there is a little vacuum motor hooked to a cast housing which is bolted to the axle. Inside there, there is a fork that slides a collar to engage or disengage the axle shaft. The most likely problems are either vacuum related(often one of the lines pulls off), or that the vacuum motor is not longer working properly.
There are many good posts on this that you can find using the search feature.
