I posted this in the 911 forum too but this will probably get more views here...
This is driving me nuts!
I have a code P0123 (throttle position sensor voltage too high) code, transmission won't upshift into 4th gear & TC lockup is inoperative. Have replaced the following items:
Governor pressure sensor (transducer) & solenoid.
1/2, 3/4 shift solenoid pack.
Throttle position sensor.
Checked and cleaned all plug connectors on transmission & ECM's.
This is a hard fault that will appear just with the key turned on after erasing the code. Don't have to start the truck.
Has anyone run across this problem? I have a feeling that it may be harness related or a possible PCM :{
__________________
__________________
