Details here: TDR Privileges
I have had the injectors out several times and now. Line no. 5 is leaking where it goes into the head. I know there is an injector install kit. Does that include everything I should need to fix this?
All you should need is a connector tube O-ring, if you do a lot of injector swaping it wouldn't be a bad idea to keep a set of O-rings in the truck for when this happens.
