What do the AC/heater and the Transfer case have in common?
I had to replace my heater core a while back. After fighting with the dash for many hours (take it out, put it back. doesn't fit right, take it out, etc) I finally got everything back to where it is supposed to be (minus the shattered dash pieces), now all I get is hot air, have to by pass core in summer. Get cooler air that way , but not nearly as cold as it should be.
Tried to go int 4WD the other day, no dice.
Problems found:
No Vacuum to Transfer case
Recirc door does not open (probably vacuum)
air director Does direct air to appropriate location. (IE floor, defrost, etc)
Any Ideas?
Problems found:
Any Ideas?
