No backup lights...
Best oil Cummins filter for 24 valve engine?
Question on Airbag Failure???
I can't find out why i have no back up lights! The fuse is fine and the blubs are ok but not lights. Even my extra ones mounted on the hitch, which have been working fine since '97 are not working. Is there a fuseable link some where? Any suggestions?
Thanks!
Brian Hale
My backup lights failed because of a bad switch in the transmission. It's probably an easy replacement but I'm not sure, I had mine replaced when I had my transmission rebuilt.
Tom
It's on the left side and screws in. You should let someone more competent answer because I don't know fot sure. Someone will probably provide more details.
Tom
My back-up switch failed, it is on the left side of the trans, (NV4500), easy fix... . then I stuck 55w halogen driving lights on the back for lighting things up when hooking or un-hooking the TT. I did not wire them to the back-up lights, a separate switch in the glove box worked for me.
Mike
p. s. lotta good that does ya... I see you have an auto
