6speed
Was traveling out west from GA with 3 cars. Wt was about 28K. As I was climbing a grade of about 5-6% and in 115 - 118 degrees and at about 7000 FT, i started losing boost At that configuration i would be pulling that type of grade in 4th gear (MT). I have gauges that tell me more than I probably need know but I have them. I ended up in 2nd and the thoughts of bad fuel, collapsed air filter or even a boot blown off went thru my mind. When i got to the top I pulled over to investigate. As I was sitting there looking and thinking what could be the problem i could here the turbo spinning pretty good. Didn't find a thing. I began my trip down the incline and everything seem normal. I have never experienced that situation before. i wonder if the altitude and heat had that effect I figure with those temps and altitude, I must have been about 14000 ft of corrected altitude. I know the turbo can make up for some of the air that high up. On return trip back to GA I had no problems what so ever and made all the boost I needed. Any thoughts? I may not respond right away as I traveling out of the US for few days. Curious as to what some may say. Have a good day
