Engine/Transmission (1994 - 1998) No boost pressure
2nd Gen Non-Engine/Transmission mag hytec
Way down on power, boost guage stays on O. I changed fuel filter,checked pre filter scren, was clean. The intercooler & hoses look ok. If the waste gate was stuck open, would that cause no boost? Problem was first encountered on the way back from california, sometimes boost and sometimes no boost. this is a 97 3500. Where do i look next? I will appreciate any help. Thanks in advance. BOB Aller Las Vegas NV
If you haven't upgraded your fuel lines they may be pulling in some air. Can you see any fuel leaks along the path of the lines underneath? Try cracking the bleeder nut on the fuel filter and then manualy work the lift pump to see if the LP is pushing out fuel there. Every rig will have some issues at some point in time. These old 12 valves are the most bullet-proof. Good luck.
55gene
55gene
Sucking wind I mean air into the fuel, a failing lift pump, and even the intake heater relays sticking on and melting the manifold-to-AFC line can all cause loss of boost and power. Do you even *smell* any fuel under the hood after driving it?
If the boost comes and goes, I would look at the waste gate sticking and / or loose hose clamps. When you have boost, what PSI do you have and how does that compare to normal? Are you getting alot black smoke out the tail pipe? (fuel but no air)
Made up a fuel pressure guage (liquid filled). Fould pressure bouncing all over the guage at idle and with rs. Pinched off return line, got 60#. Have pressure relief valve coming from Genos. Thanks for the tips. BOB
Found the problem
Exaust brake was partially on. BD brand. Selonide valve is bad. Have a new one on order. Wired exaust brake open, got the zoom back (30#) boost. Stretched the spring in fuel pressure valve, got 20#. Had no smoke before, now i get smoke on full exceleration. Genos new fuel pressure regulater was shiped today. Thanks ever body for the tips. I am recouperating from a heart attack , april first. Some days i dont feel good enough to walk the dog around the block. Iam geting better.
