No brake lights on 03
Trip Computer MPG Accuracy?
Any heads up with the 06's?
I have an 03 quad with no brake lights . The third cab brake light works . . just no brake lite on either side. I looked for the fuse under the fuse cap... I can find everything but the brake fuse... any one know which # it is ? or is it some where else. ?or is it a circut breaker?. the dash says... " lamp out". . thanks... ... ... ... ... ...
I wonder if it's the bulbs on each side. Has the light been on long or did it all start at once?
It seems odd to me that you would have the center, but not the rears.
There's been some posts about the sockets melting on our early 3g's. You may want to take one of your tail lights apart to inspect. If so, I sure hope the new part is improved.
the tail lights are computer controlled while the third brakelight is controlled by the pedal switch.
there could be a computer issue or like mentioned earlier.
No Fuse??
I dont know when it started as I bought it used. So is there no fuse for this? thanks again... ... ... ...
