I just replaced my rotors,pads, and front calipers this weekend. So I added fluid to the master cylinder pumped on the brakes about 30 times until I finally got some pressure, and as I'm holding it, it just goes all the way too the floor. So I pump it again, same thing again. I don't know whats going on. Next I open the bleeder valve on the left front caliper to see if i'm getting fluid, and I am,by gravity flow. do the same thing on the passengers side also, same thing. So I have my friend pump it again while i'm at the bleeder, the fluid pressure is the same with pressure on the pedal as it is with the pedal depressed all the way to the top. I thought that when I went with the new calipers that the old master cylinder didn't have enough pressure to push the new calipers, and was bypassing, so I went and got a new master cylinder today, bench bleed it free of air. Installed it and got the same results as with the old master cylinder
Man this getting me ticked off
Oo.
Is my ABS or porportioning valves gone bad. Ive never had this much problem before?
