Engine/Transmission (1998.5 - 2002) No BUS signal
Engine/Transmission (1998.5 - 2002) Fuel Line Help
I have 2002 24v that I converted over to the p pump. It was running and got to a red light and it died!! I am getting No BUS signal. The timing on the pump slipped and I set it back, hot wired the FASS to a switch and it still won't start. Any input will help.
Thanks
No BUS means no communications between the ECM and instrument cluster. I'd guess there's a rollover shutoff solenoid in the fuel line somewhere and it's controlled by the ECM.
I have no idea why the ECM isn't working. If you have a ODB II reader it should be able to communicate with the ECM if there's any life in it.
