My 93 W350 stopped charging so I did what I know and now I need what you know. The alternator is fine, putting out about 30 amps on the bench, the crank position sensor is new and I think adjusted properly. The multimeter shows no power at either of the field connections when the key is on and engine not running, after starting I get about 4. 5 amps on each field terminal. I don't know how to check the engine computer (PCM)? Any ideas? Thanks.
