Engine/Transmission (1998.5 - 2002) no chargeing
Engine/Transmission (1994 - 1998) AFC boost line leaks
Engine/Transmission (1998.5 - 2002) 0236 code
was wondering if anyone know if you can get an ecm fixed for the voltage regulator,my truck quit charging and i replace the brushes and bearings in the alt,found out the voltage regulator is in the ecm,can you test this or do you just by a new ecm or can you get them fixed,thanks
On the 12 valves the EVR is in the PCM. I thought all 2nd gens had the
EVR in the PCM ( which is on the fire wall behind the passenger side wheel well).
Are you sure you didn't pop the fuse in the PDC ( black box behind battery).
You can put a external regulator on to check to see if it will charge. If it does you can leave it on get new PCM/ECM which ever one the EVR is in.
