U1421-IMPLAUSIBLE IGNITION KEY OFF TIME RECEIVED
For a complete wiring diagram, refer to the Wiring Information.
Theory of Operation
This monitor checks if the timer that counts the ignition off time is stuck.
When Monitored:
Ignition on.
Set Condition:
If the difference between coolant temperatures at the previous ignition off and next key on is greater than -12. 2°C (10°F), and the ignition off time was less than two minutes, the Engine Control Module (ECM) increments a fail counter of one. If the fail counter reaches 16 counts, a DTC is set and MIL lamp turns on.
Possible Causes
CAN B OPEN OR SHORTED
CLUSTER MODULE
TOTALLY INTEGRATED POWER MODULE (TIPM)
ENGINE CONTROL MODULE (ECM)
Always perform the Pre-Diagnostic Troubleshooting procedure before proceeding. (Refer to 28 - DTC-Based Diagnostics/MODULE, Engine Control (ECM) - Standard Procedure).
1. ACTIVE DTC
NOTE: Low battery voltage as well or an IOD fuse which is missing or not pushed in completely can cause the DTC to set. Make sure that the battery is fully charged and Ignition Off Draw (IOD) fuse is properly installed before continuing.
1. Ignition on, engine not running.
2. With a scan tool clear DTCs.
3. Turn the ignition off.
4. Turn the ignition off.
5. With a scan tool read DTCs.
Is the DTC active at this time?
Yes
Go To 3
No
Perform the INTERMITTENT CONDITION diagnostic procedure. (Refer to 28 - DTC-Based Diagnostics/MODULE, Engine Control (ECM) - Standard Procedure).
2. CHECKING THE ECM POWERS AND GROUNDS
1. (Refer to 29 - Non-DTC Diagnostics/Drivability - Diesel - Diagnosis and Testing) and perform the CHECKING THE ECM POWERS AND GROUNDS diagnostic procedure.
Were any problems found?
Yes
Perform the appropriate repair.
Perform the POWERTRAIN VERIFICATION TEST - 6. 7L. (Refer to 28 - DTC-Based Diagnostics/MODULE, Engine Control (ECM) - Standard Procedure).
No
Go To 3
3. CHECKING FOR TSB/ECM FLASH UPDATES
1. Check for any Service Bulletins or ECM flash updates that may apply.
Were any Service Bulletins or ECM flash updates found?
Yes
No
Go To 4
4. CAN B BUS HARDWARE DTCs ALSO ACTIVE
1. With a scan tool check for DTCs in the TIPM.
Are any CAN B Hardware related DTCs active at this time?
Yes
(Refer to 28 - DTC-Based Diagnostics/MODULE, Totally Integrated Power (TIPM) - Diagnosis and Testing) and perform the appropriate diagnostic procedure.
No
Replace and program the Engine Control Module in accordance with the Service Information.
