No Crank
4WD indicator switch location...
Dead links to shop manuals.
I have a 96 4x4 w/nv4500. Just recently it started cranking slower and slower. Thought it was the starter because the batteries were fully charged. Put my spare starter on, still cranked slower and slower until it only clicks now. Will not start with jump function on charger either. Thought the battery cables were bad(they looked terrible) made new cables and installed. Still only clicks. Checked the starter relay and it's good. So......anyone with some good ideas to check?
Warren
Warren,
I would recommend you load test the batteries individually. Also check the bonding strap from the body/frame to block. All indications point to bad battery. How is the alternator output?
Warren,
Batteries are almost brand new. Are holding 12.3 after 2 weeks of not running. Never considered that I might have a blown strap at the bottom of the bat tho. Thanks
Have a multimeter ?. Attach to battery facing cab, try to start and see where the voltage goes. My last ones dropped to 5vdc trying to start.
I still recommend a load test on each battery. David's headlight observation is a quicky test as the starter draw will pull a lot of amperage. If the amperage is depleted and the headlights dim significantly during a start session one or both of the batteries are weak, or a bad connection somewhere in the circuit. What does the voltmeter read during and after a start session?
Yes, load testing will give the definitive answer if it can be done.
Ok, had the bat's load tested and are marginal. Has anyone upgraded to series 31 batteries on their truck. I need battery trays 13.25" long. Stock ones are only twelve and a quarter long. Warren
Ive actually got group 24s in mine. Thats what the shop put in a couple of years ago when I was having trouble starting. The 24s actually out spec'd the group 27s. I like em. Interstate.
If you get longer bolts, the group 31 will fit. DONT do it on a cold day though. It's TIGHT!
My 1998 12 valve has had 31's in it for almost 20 years now.
Instead of longer bolts you can just turn the clip over that slides over the battery tray that will put the threads at the top and allow the battery holddown bolts to grab
