Details here: TDR Privileges
I was hoping you guys could help me with this little problem. my cruise control no longer works after i swaped out my auto for the 5600. I have seen a thread about this a while ago but cant seem to find it, any ideas??
when i did my swap mine did not work either cause i just grounded the nuteral saftey so the truck will start that also made the curise quit working then i put a switch on the ground wire that i could flip after i started it and that made cruise work and it worked for a couple months then quit working again
Also, when I did my conversion I tried removing my TPS since I figured I didn't need it anymore. I was going to donate it to someone who might need it. Without the TPS in place the cruise would not function. I guess it feeds info to the PCM which works the cruise. I put it back on and the cruise functioned as it should.
If you don't find your problem, try contacting Jim Leonard. He goes by "Dieseldemon" and he is THE man on these transmission swaps and he is ALWAYS graciously helpful.
