I need help from the Gurus... . The cruise control has quit. The vacuum is good, and the servo checks good as explained by the shop manual. Where to next???
Symptoms are as follows: Once up to speed, press the On/Off button and the indicator light comes on, however the set/coast switch does not activate. 50 seconds after the OD light comes on, the light goes out by itself.
Using the trouble code system with the ign switch ( On-Off-On-Off-On) shows a code of 77. I have no defination of trouble codes above the 60's range.
Any and all help greatly appreciated.
