My electric trailer brakes stopped working. It had worked before, but no more. I use the prodigy controller, have had it for about 18 months. It shows the trailer connected, and when you slide the manual brake enagagement, the trailer brakes work. All lights on truck and trailer work. However when you depress the brake pedal, the electronic trailer brakes do not work.
I used a voltage meter to confirm that the voltage to the wire going to the prodigy controller does not change, 0 volts all the time. Obviously power is getting there because you can manually engage the brakes.
I also checked each and every fuse, none were blown.
I recall hearing that all lighting controls actually go through a computer on these trucks.
Can anyone think of a way to fix this without taking it to the dealer?
