no first gear in A518
Broken cam, What else to check
1993 4:10 to 3:73 gear swap???
I lost first gear in my 92 about 20000 miles after a rebuild. I checked the linkage and that seems to be ok. Little sloppy but it is engaging all the way. Haven't had the pan off yet.
Valve body issues, stuck shift vlaves, worn governor bore plugs.
Front servo, either cocked in bore which is a failure point or possibly front band linkage damage.
Thats a couple things it could be, are probably more that could contribute.
Thanks for the ideas, I'm not much of an automatic mechanic and the guy who rebuilt it for me sold out.
Where is the governor pressure solenoid located or is there one on a 92?
