I do not know if there is a fuse dedicated just to the stock lift pump, but if you are seeing 0 PSI, then I'd say it's a 99% likelyhood you have a dead lift pump. By the way, the pump can still run and be dead at the same time. Mine did just that when it died last month. Something inside the pump gives out, and so you can hear it running, but it isn't pumping any fuel.
Tom
